Rlee1773
Bought a new pcv valve because the old one is kind of loose. New one causes a rough idle. Put the old one back in and it idles fine? Not sure why.
Try shaking the new one, and listen for rattling. You should hear something. If not, the valve is defective (causing a vacuum leak)Bought a new pcv valve because the old one is kind of loose. New one causes a rough idle. Put the old one back in and it idles fine? Not sure why.
It does rattle. Ive tried 2 different new ones and both cause a bad idle.Try shaking the new one, and listen for rattling. You should hear something. If not, the valve is defective (causing a vacuum leak)
Its not. But neither was the old one and that one worked fine. Do you have a link for the motorcraft one?Is it a motorcraft
Interesting. Assuming they are the same dimension wise on the outside, does it have any sort of grommet it seats in? I have a 95 (5.0), and there is a rubber grommet that the valve sits in. If yours is worn out, it could cause a vacuum leak. Now because your old one seems to allow the car to run good, I suggest trying a Motorcraft one if no one else posts an answer here.It does rattle. Ive tried 2 different new ones and both cause a bad idle.
