Pi 4.6l 2v cam bearings
Nick124
I bought a set of 01 pi heads and when disassembly them I dropped one of the cam bearings and damaged it. Can I buy new cam bearing and put them in, or is a more lengthy process?
lwarrior1016
Mr. Secondary Timing Chain
Staff member
South Mississippi
Good luck man. That repair is not very common. You might be able to look at the number on the bearing and find the manufacturer.
96blak54
Staff member
Lawrenceburg Kentucky
Possible ACL brand
Hard to provide a definite answer. The machine work to your head most likely is specific to your bearings regardless of brand. Looking at available cam bearing options for the modulars, the descriptions dont give technical data to the bearing dimensions.
You might get lucky and mend the bearing you have back into shape. Also, look at all the brand bearings, match your bearing up and make a choice. Hopefully youll get the same. I have a bunch of measuring tools and could figure out exactly whats needed. Just like a machine shop could. If you would be more comfortable letting a shop handle this, thats what you should do.....but youll still be buying bearings.
Whiplash-Smile
If you can’t source a new bearing, clean the bearing shell thoroughly, break out your 1/2” socket set and locate the socket that most closely matches the diameter of the cam journal - gently try to conform the shell around the socket by hand initially focusing on the middle of the shell and not the ends initially - gently is the key here, no kinks or marring the babbitt. Once you get the shape approximately what it once was place it back in the head(it’s actually easier to use the bearing cap in a aluminum jawed vice) and use a rubber mallet( not brass or steel) to gently tap the socket forcing the shell into the cap - it helps to apply pressure on the shell ends down into the cap while tapping the socket. So a second set of hands is.. well.. handy.
You can get it close just by the above technique.
Pop the followers out of the head so there is no valve spring tension on the camshaft.
Oil the camshaft and journals up then finger tight all the caps and see how easily the cam spins - you can spend a couple of hours and get it damn near perfect. It may be worth your time to do this rather than source a new head
Also torque the cap in question down once and then back it off until finger tight before attempting to rotate the camshaft by the timing gear - and do it by hand - you want to FEEL any drag. Gradually tighten all caps in factory torque sequence until you do or don’t feel drag. Any issues will usually show up at the cam ends - This might save you some money
Whiplash-Smile
I am looking at the pic you posted of the bearing shell - that looks to be just aluminum is that correct? No babbitt would likely make it a bit easier, but gentle and slow still applies
Testguy
