PI head Swap or PI Motor Swap???
Stanghead96
which is the best way to go for someone on a buget ??
i know the head swap would be cheapest in total but is it the smart way to go with a NPI block that has 95k on it?
thanks
Rantheman
P.i head swap can be cheaper but if you do the whole motor you will have a less compression ratio you can but bigger cams in with the deep dish pistons for not a whole lot more
scarface
Guest
depends on the prices you get the parts for and the labor. Heads are cheaper, but labor is extensive. Check around on prices
gjhanick
