Want To Buy PI heads
joshuaw3
Ohio
Looking for some pi heads at a reasonable price. Bone stock or already ported and what not. Let me know if anyone has any.
D3VST8R96GT
Marble Fall, AZ
I have some stage 3 (mhp) 9thread heads and .600 springs They need about 300 worth of work/repair. I won't sell them until they are fixed.
D3VST8R96GT
Marble Fall, AZ
Actually looks bad but that's the easy fix
The plug boss is the hard repair.... let me find a pic...
Like I said I won't sell until I have them fixed professionally.
J
joshuaw3
Ohio
Ok well will the Windsor heads even work on a Romeo block? Aren't the mounting points different? I'd be interested if they will for sure work.
D3VST8R96GT
Marble Fall, AZ
No they mount the same .... I have valve covers (they are a different bolt pattern)
It's the timing cover I'm not 100%, I havent personally had a Windsor 4.6.
J
joshuaw3
Ohio
Hmm I wonder if anyone on here knows about that timing cover?
torch318
I have a windsor cover on a romeo block the bolts are a different size.
D3VST8R96GT
Marble Fall, AZ
Ok thanks! I never really tried to mix the romeo and windsor stuff. I wouldnt do it unless i have a complete engine of each.
J
joshuaw3
Ohio
But what about a Romeo cover on Windsor heads? Still different bolt sizes you think? How did you get the right bolts that you needed?
You can use the Romeo timing cover with the Windsor heads you just have to pickup the right bolts that go through timing cover into heads.
Check out the how to threads in the 2V section for part #'s.
I actually have some in storage but I will include those when I sell my Windsor heads ported by Fox Lake soon.
wbarter
