So in searching, I've found an 05 pi motor complete, with only 51000 miles on it. Wondering what y'alls opinions are? Sent from my SAMSUNG-SM-G890A using Tapatalk
Do not buy any engine unless you hear it run! The swap is a good one, but lets figure out what the desired end results are. Directly swapping will only gain you stock hp, although its an improvement over the npi its still stock. So question here is.....what do you want? What are your future goals?
Future goals are just more power and beastly sound. I've got a lock on pi heads for 100 bucks today. Just looking for opinions from the brethren on here. Sent from my SAMSUNG-SM-G890A using Tapatalk
I love to build, so I always vote PI head swap. If you went that far would you be doing rings and bearings? Then the big question comes in, how long are you ok with the car being torn down and do you have the facility to build an engine?
I have three cars so time wise is ok but the spot to work on it is in? And not sure about rings and bearings Sent from my SAMSUNG-SM-G890A using Tapatalk
05 should have the latest version of 2V heads but that isn't exactly cheap but if its complete and in good condition it would be an easy drop in.
Low miles is a plus. Could source out a set of 3cc cobra pistons and get the valve notched. Swap them in annnnd.....then youll be ready
Ive done both.. To the same car. Honestly, there was no noticeable difference imo. If it was me, i'd probably do the entire motor swap IF you can find a low mileage 2v motor. Otherwise, I would just do some bolt ons to the non PI motor and some cams.
Ended up just getting the pi heads for the swap for now. 100 bucks well spent Sent from my SAMSUNG-SM-G890A using Tapatalk
My friends 1996 Gt is PI swapped on the bottom end, only have 95k miles on it. Unfortunately he got into a car accident around his quarter panel and rear end. I drove his car before the accident, and runs tremendously great. I'm buying his car so I can swap his into mine since my car has at least 236k miles in it.
Sweet deal! Now how can we swap them pistons out....hmmmm? ...lol Do you want to stay naturally aspirated more hp? Or forced induced? Which both lead to getting dyno tuned $$$. BUT Oh so worth while!
Gonna stay natural. And stlmustangs is close by for the dyno Sent from my SAMSUNG-SM-G890A using Tapatalk
I just finished the pi top end swap, and you won't be disapointed! However that 100$ is going to turn into more like 500 real fast. You will still spend 250 on an intake, 100 on gaskets, 50 on headbolts, then there's motor mounts, machine shop work on the heads, etc. As far as difficulty wise, it's very easy. I'm 15 and i did it in my garage with no problems at all. I didnt do rings or bearings because my car only had 130k, so I'm not sure how difficult that's going to be. The end result will totally be worth the effort Sent from my SAMSUNG-SM-G530A using Tapatalk
