Pi Swap Serpentine Belt Length
Willis_98GT
DFW Texas
Do most people get a longer belt after they do a PI swap?
On my car i retained the NPI Alternator and Timing cover i had initially before anything. So my question is
With the bigger heads/intake etc it has lifted the alternator bracket higher meaning that a stock length belt is stretching in theory. When i have the AC on it yanks the engine when it kicks on.
Should i look into maybe a stock length +1inch or something?
I'm probably just crazy
96blak54
Lawrenceburg Kentucky
Im thinking ...crazy....lol
I cant see why a longer belt would be needed. Your using all the old covers, the heads bolt up the same, all the accessories bolt on the same.
If you are having trouble, the belt tentioner would be max travel trying to get the belt on. So...yea sure ...1" longer is a good start.
W
Willis_98GT
DFW Texas
I may just leave it as is then. I know i'm crazy, its been one of those mornings
DropTopPony
South Jersey
I reused everything, if there is a difference the tensioner should adjust enough to compensate.
texasvoodu
