PI swap/vortech
97stanger
i have a 1997 auto gt, with basically every bolt on you can do...my next mods are going to be as follows
Mongoose Kit SQ trim
Full PI swap
Custom grind blower cams
just curious as to how much power you guys think ill be making?
scarface
If you are planning on 8 psi like we talked about probably about what I make...But remember I am a 5sp. you are an auto...same numbers on a dyno dont translate to the same track times.
If you are curious email Jason at steen racing
97stanger
97stanger
yeah im doing the headswap also, i honestly dont think ill be that high, just hoping for somewhere between 380 - 400 rwhp
sounds sweet, you'll like that!
HP will depend on how much boost you run.
it will certainly be capable of that.
97stanger
97stanger
i'm only going to run 8 lbs because of the increase in compression...
97vertstang
Snakebit said:
thats what I was going to suggest, plus use a intercooler
+1 on the intercooler, thats going to be a lot compression for a blower, so make sure its not pinging!!!!
scarface
he will be fine as long as he has a solid tune. I suggested meth. injection regardless of IC or not.
Daywalker
Can't you just thicker gaskets to keep the compression down? 40 is standard right? What size would be good if planning on running a blower/turbo later on? 50? 60? :dunno:
scarface
with the thicker gaskets I would think there would be a higher chance of blowing them out.
It's called a Cometic Gasket.
It does lower the compression.
But, it's not cheap, and any good tuner can get a blower running well on 10.3:1 compression.
svtboy
PI intake and cam swap with a vortech aftercooler.... Keep the lower compression !!!!
Ccrider
