Picking the right wheelspacer for my 98' GT
Sn95.Draconis-Kev
Netherlands
I need some feedback on this as this is my first time getting wheelspacers. I measured the gap between the outside of the tire and the fender and the difference between the front vs the rear is quite substantial. 1cm (0.4inch) on the front, and 5cm (1.97inch) on the rear.
Right now the stance of the car looks silly because the back wheels sit so far in the fenders. My question is; what wheelspacers do you guys recommended to run on the rears, making it look a lot better without running into issues with the inside of the fender?
If I were to close the gap between the front and the rear it would come down to 4cm (1.57inch) spacers which is quite a lot.
PNW Mike
Why not get wheels with an offset that puts them where you want them? If you change wheel offset so that the outside edge of the tire moves out 1.5" that means you can fit a 1.5" wider tire by using a wheel that extends further inboard. You can more traction, wider tires look better, and the tire is aligned with the edge body better. It solves multiple problems at once. :)
I run staggered wheels and tires on my '97 GT to get the look I want and get a wider tire in the rear. The only downside is that with directional tires, tire rotations at home are not possible. I can only rotate them side to side on the same axle due otthe staggered setup and with directional tires it would require dismounting the tires and remounting them reversed so I could swap them side to side. Everything is a tradeoff in life.
If you do decide to run spacers, if they are more than a few mm, make sure you get hub centric ones. The wheel center needs to fit snuggly on the hub as that's what locates the wheel positively on the vehicle. The lug nuts just hold the wheel to the car, they do not ensure it's centered on the hub. The hub usually extends enough to get a few mm spacer on there without any issues, but for anything thicker, the spacer itself needs to fit snugly on the hub and have a lip of it's own for the wheel to center on it.
Here is an example of a hub centric wheel spacer that's 1/2 thick and uses original wheel studs, though you may need longer ones: https://www.cjponyparts.com/maximum...r-5-lug-mustang-1979-1993-1994-2014/p/WHSP12/
Thicker wheel spacers they have their own wheel studs and get bolted to the original wheel studs: https://www.americanmuscle.com/mustang-150-inch-5-lug-wheel-spacers-black-set-of-two-yhtwsp0020.html
This is a random pic of a non hub-centric spacer, it just spaces the wheels out and doesn't center on the hub. it's basically like putting a big washer behind your wheels and requires the original hub to extend far enough to still support the wheel. I've used 3mm spacers on another car without issue, but how thick you can safely go with a spacer like this varies based on the depth of the original hub.
To be clear, I'm not endorsing any specific product, just showing examples. Wheel spacers are a bit of a controversial topic and some folks despise them in any form. If you're going to use them, get the right style and get a quality brand. All of the weight of your car is sitting on them.
However you roll with this, just keep in mind you'll be tosing more stuff up on your fenders with the rear wheels further out. I think it's worth the tradeoff to have the tire sit further out closer to the edge of the body, but if you do stuff like drive on gravel roads or long driveways a lot, it may be a consideration for you.
Sn95.Draconis-Kev
Sn95.Draconis-Kev
Netherlands
Thank you. I am aware of needing hub centric spacers, so I will definitely look out for that. The reason why I want spacers in the first place is cause I have 2 sets of original rims for this car which I plan to use, especially for car shows etc. I will eventually get wider rims for daily use, but I do still want the option to run the stock ones. I am aware that running spacers is not fantastic for the suspension triangulation of the car, but I do want to give it a go. The car looks so weird like this cause the rear is so far tucked in.
Terrorist 5.0
When I was considering running wheel spacers (I didn't go through with it as the gap didn't bother me much anyway), I stumbled across a forum post with pictures for your exact setup.
This forum posts includes pictures of a 97 GT running 17" factory wheels with 1.5" spacers. Should be an exact replication of what you are trying to do.
As for fender clearance, you could try rolling the fenders, but you risk cracking the paint somewhat, even when done professionally.
By the looks of the pictures in the link I provided, I think a 3/4" spacer would clear the fender completely, but this is just eyeballing it.
PNW Mike
I'm glad to know that you understand why hub centric spacers are needed, and the issues with using them.
If you want to keep those wheels as-is, then spacers are pretty much your only choice to move the wheel out further in the wheel wells, short of modifying the rear axle/suspension for a wider track width, which is not cheap. A set of good 1.5" spacers is not terribly expensive, and you're only putting them on the back so it will be easier on the suspension vs doing spacers on the fronts. My understanding is that solid rear axles are not as finiskcy as IRS when it comes to wheel spacers and track width.
I've heard of guys sending wheels out to be modified so they can get custom fitment on stock looking wheels, but why bother when aftermarket wheels are so easily obtainable? :)
Terrorist 5.0
He could swap in a New Edge axle, they give you another 0.75” of track width if I am not mistaken, and you get 3.27’s. That is a huge upgrade if OP still has 2.73’s, especially for a 4.6.
shovel
new edge axle is ~40mm wider (20mm per side) - I also think with stock wheel offset a 20mm spacer looks pretty good but you would need to cut your lug studs to fit them. If I was buying spacers today for a sn95 with stock wheels I'd go 25mm just to avoid dealing with the lug studs... but going too far kinda looks goofy too.
20mm pictured below:
Vmarch
