Pics of fluidyne radiator install
fixthedoor
This Saturday I installed a new Fluidyne radiator, March underdrive pulleys and a FR water pump. The radiator looked bitchin. I was skeptical about how everything would fit once I got it in, because it is twice as thick as the stocker, but it really was a non issue. It fit real tight on the passenger side and I had to modify the fan shroud to clear the tranny lines, but these were the only speed bumps. From set up to clean up, it took a little over 6 hours, excludes 2 hour test time :dancing6: . After everything was said and done, I was more than satisfied with everything. I won't know the full abilities of the radiator until I expose the car to some good ol' LA traffic in the summer.
[attachment deleted by admin]
Suspect
ATL
nice man! :thumb: i forgot how thin the stock radiator was, wow. :eek:
F
fixthedoor
I know, it's a little scary. I fully understand why she damn near overheated coming back from Vegas one summer a few years back.
F
fixthedoor
Pennywise2 said:
The Fluidyne radiator should fit like a glove
and fit flush with everything.
It did, but that was the first thing that went through my mind when I started comparing the two. Then again when the radiator was in and I was staring down at the resevoir lower bracket. The tranny lines, though, were bent too close to the radiator and if I did notch out the fan shroud I think the fan would have gotten stuck. It's all good though.
Rsf1013
