Please HELP
Eastcoast5.0
Car is shuddering horribly...codes are:
314 Therm Air System Not Working Bank2
311 Therm Air System Not Working Bank1
If anyone has had this code PLEASE help. Ford said the code is very broad...vaccume lines, emmisions, smog, etc. I've been running around trying to figure this out for a weeks and havn't been able to get it, the car is such a pain in the ass to drive!
95KBGT
check all your hoses, and emissions. there also is a big hose under the cai that could be disconnected.
E
Eastcoast5.0
Thanks. I just checked a few and they seemed ok. I'll take a close look later. I Took the belt off and spun the smog pump and it would spin freely then suddenly stop...is that normal?
95KBGT
Im not too sure about that, also make sure you inspect all the hoses for dry rot at the ends especially, i had that problem in my jeep, everything was connected and looked fine, and then i started pulling off hoses one by one and found many of them cracked and barley on.
d_punch
if i knew there was a way to check your 02 sensors, i would tell you how. but the only way i know to tell if they are bad is to change them.
d_punch
i would also check your plug wires to see if any are burnt or in bad shape, and also pull the plugs to see if any are fouled.
E
Eastcoast5.0
Replaced o2 sensors AND plug wires no go. I disconnected the battery on friday and played with some of the vaccume hoses and smog shit...it all looked fine. I put it back together and quickly cleaned to MAF...ever since it's been back to normal some how. I cleaned to MAF a month ago so I'm a little confused but happy she's back to normal...for now.
RobertC
