since i am learning about the 95 mustang gts and how to maintain them......since i am buying one next year and i need to know all info about em.....thanks and
Specifications: Year: 1994 Make: Ford Model: Mustang GT Base Price: $17,000 USD Origin: Detroit, Michigan, USA ¼ mile: 15.0 Seconds 0 - 60 MPH: 6.6 Seconds Gas Mileage: City: 18 MPG / Hwy: 26 MPG Position: Front Longitudinal Configuration: Cast Iron, V8 Valvetrain: OHV, 2 Valves per Cyl Displacement: 302.0 CI / 4950 CC Power: 215 BHP / 160.3 KW @ 4200 RPM Torque: 285 FT LBS / 386 NM @ 3400 RPM Redline: 5900 Bore: 4.0 IN 102 MM Stroke: 3.0 IN 76 MM HP/L: 43 BHP per Liter HP/LB: 15.8 LBS per BHP Drive Wheels: RWD Curb Weight: 3405 LBS 1544.2 KG Steering: Rack & Pinion Materials: Unit Steel Front Brakes: Vented Discs w/Vacuum Assist, ABS Front Brake Size: 10.8 IN / 274 MM Rear Brakes: Vented Discs w/Vacuum Assist, ABS Rear Brake Size: 10.5 IN / 267 MM Front Tires: 245/45ZR17 Rear Tires: 245/45ZR17 Front Suspension: MacPherson Struts w/Lower A-Arms, Coil Springs, Telescopic Shocks, Anti-Roll Bar Rear Suspension: Live Axle w/Trailing Arms, Coild Springs, Telescopic Dampers, Anti-Roll Bar Transmission: 5-Speed Manual 1st Gear Ratio: 3.35:1 2nd Gear Ratio: 1.99:1 3rd Gear Ratio: 1.33:1 4th Gear Ratio: 1.00:1 5th Gear Ratio: 0.68:1 Final Drive Ratio: 3.08:1 I don't claim to be exactly accurate...especially for the ET...in the 14 second range more likely.
