NEW EDG
NoVa
Grabbed a Steeda Triax to hold me over until I do the T56 swap. I was between this and an MGW. Figured I would go MGW on the T56 if I didn't like this, but I'm quite happy with my Steeda purchase. With the Cobra Bob gaskets it's pretty much silent, works perfect and fits like a glove. Will definitely go back to Steeda for the swap.
What did you use for heat shielding on the trans tunnel/firewall for radiant heat transference?
I can't remember what I used exactly all those years ago when I put the heat shield on the trans tunnel, I just got a little bit of this stuff to put above the cats.
As an Amazon Associate we earn from qualifying purchases.
I wish I could tell you what I put up because it did save some burned paint in that area. The adhesive on the back has held up perfectly and all I did was wipe the black off of it.
that's not too bad, I could wear it.
Today I received an assortment of cable mounts and heat shrink as well as some more heat wrap for my latest wiring project. After looking at how I had some of the wiring ran I decided to pull it down and do it again. I have always been a big fan of using wire ties to secure things under the car but that is going to stop. If it can't be hard mounted, its not getting ran now.
95opal
Zipties are great for temporary holders while running wire and hose but not for final mounting. Always go back and hard mount everything. Last thing you want is for a ziptie to melt or fail while driving. Ive seen it happen countless times.
nynce
