Thank you. I've had them in the past but decided it's time to go back and get another...
Nothing else being sold - it's an addition to the fleet!
TMW
does it have that wind deflector in the back with the backwards toyota badge that shows normal in the rear window? My neighbor had one when I was a kid and I thought it was just the coolest little touch for someone to think about.
tmwsccsh
England
I think that was only the MK1. Could be wrong but I am pretty sure I know what you mean but never saw it on a MK2.
But it does have both the sun shades and the bags for the t-tops. They are as rare as hens teeth attached to a snowball in hell...
TMW
TTSaleen
NC
Got the Anderson Valve Covers on and attached an Evil Energy catch can setup with 10AN lines.
Installed the On3 Performance hat and fuel pump (Hellcat = 525lph).
A few things -
1. The 6AN ORB threads in the hat were not cut correctly. I had to purchase a 9/16-18 tap to cut the threads and allow my fittings to be installed.
2. The wiring to the pump from the hat was wrong. I pulled the connector apart and swapped the wires to opposite sides.
3. The mounting arm was too long with my pump mounted and would not fit in the tank correctly. I cut the bottom of the arm off and moved the pump up slightly.
*** Lots of extra work that should not have been necessary!
Started installing the Vortech Superchargers bracket last night. Will finish this up today hopefully.
Vortech/Summit/Jegs are all on backorder for the return line and the radiator cross over tube.
I got some fittings and line to make my own drain system (will attempt it today).
As an Amazon Associate we earn from qualifying purchases.
I assume that pic is the "Before" you switched the wires? Strange and annoying but I have seen it happen. Back when i was installing stereos fulltime I remember as I finished up with a deck install and was going through the post inspection checklist to make sure everything worked after i was done, as soon as I turned on the lights the deck lost power. After a quick check I mean it lost ALL power and then would not turn on at all and this was of course as the customer was waiting for me to get out of the car. I pulled it back in and found a blown fuse, rinse and repeat and again lights on/deck off. Turns out the ground wire was swapped with the illumination wire so it worked, till the lights were on...
whiplash473
Northern IL
Not having an operating pickup for the first time in my life is a strange adjustment.
My oldest daughter and I race BMX in our respective classes. Her bike fits in the 4Runner but mine doesn’t and the spring session starts on Wednesday. So my wife found a Thule rack on marketplace for $40. We loaded up and grabbed it this morning.
Edit: excuse the pile of Tahoe in the driveway. It isn’t mine and was supposed to go back home weeks ago. If you’re curious, both bikes do fit in the Tahoe.
bmx!? No way! I had always wished they had a track someplace close when I was growing up but it never did happen. I settled for mountain biking and love it but still today when I see the races I wish/want to do it.
whiplash473
Northern IL
We are very fortunate to have a nice track two towns over. It's a blast.
Lucky57
