Post your 1/4 mile track times
EVILSN
I've searched and couldn't find a thread with 1/4 mile times and your combo, so post um up!
308
Drummond built x heads
E cam
1.72 rockers
Vic jr
Demon carb
Sent from my iPhone using My dick
cameron57
308
E cam
1.72 rockers
Vic jr
Demon carb
Im going to guess you were right lane. Not bad times you could pick alot of time if you were on getting your 60' times lower. One number in the 60' is two on the big end.
Sent from my SAMSUNG-SM-G920A using Tapatalk
EVILSN
EVILSN
Thanks, the second pass was a 1.71 60. Bent a pushrod top end, turns out comp guideplates don't like stock pushrods.....
Addermk2
its not the guide plates, its your springs. You need a set of hardened pushrods. I suggest Comp Cams Hitech chromoly.
EVILSN
EVILSN
Thats what I used, comp chromoly, when I put it back together I actually clearanced some of the guide plates, the pushrods fit right in a few.
EVILSN
EVILSN
*Tight in a few
Addermk2
You might need a set of adjustable guideplates. I have found, many times, that different heads have different valve offsets, and require specific or adjustable plates.
EVILSN
EVILSN
Thanks adder, if I have any more problems I will swap those guide plates out.
bs.austin.tx
