Power steering options?
Daryl
SoCal
Just wondering if there are options/upgrades to the stock power steering rig? I’m ok with it, but I’m just curious???
RAU03MACH
NEW MEXICO
quick steer ratio
check into it but I think your talking mustang 2 rack and pinion
the steer is a little more sensitive quicker ratio
had one on my 92 can not remember the numbers but I got it from summit and the make
was flaming river
Daryl
Daryl
SoCal
No electronic steering?
07GtS197
Fort Myers, Fl
Not plug and play but you can do the Volvo electric power steering pump. It still uses hydraulic pressure but the pump is electric. In my opinion it’s not worth it unless you coyote swap it.
RAU03MACH
NEW MEXICO
Just remember the more Electronic you add the alternator will need to be upgraded on a 347
Everything Electronic robs power
Daryl
Daryl
SoCal
Whoops, you just said the magic phrase, “robs power “.
Nevermind!!! I’ll keep what I have.
TrickVert
Woodland Park, CO
Not necessarily. EPS uses power only when active. The vast majority of the time, it's idle. Conversely, the hydraulic PS pump is *always* being driven and pumping fluid, drawing HP from the engine constantly.
Daryl: HERE is some good info on converting. I know someone undertaking it on a Foxbody. I can get you connected if you're interested.
07GtS197
Fort Myers, Fl
I’ve read about people swapping those into other cars but never in a mustang. It would be pretty cool. But for the mod motor guys the Volvo esp is a better choice since the brakes work off the steering pump too. Just a little tidbit.
RAU03MACH
NEW MEXICO
it can be done I see a lot of modifying the steer coulomb down
and then wiring schematics
but I would try to keep the rack of cores
and have a mechanically incline mad mind to do it
Vallybell
