I replaced the entire motor/regulator assembly really only because I already had the glass out and figured it was easier to do this far in and the old assemblies should have been on borrowed time after all this time. After I replaced the regulators I thought the window went up a little slower then I the old one but figured it was just a low battery or something as it was not horrible. Then I decided to replace the window seals since one was looking ratty and one got tweeked a bit while taking it off. Now with the new seals it goes up really slowly and then stops about 3" from the top and this is when its on the battery charger so I know its not a power problem. I thought maybe it was because the seals were new and just needed some time to work into the right shape but now about a month later it still stops 3" from the top. I have tried cleaning/greasing the window tracks, I tried loosening the bolts holding the motor thinkging maybe it was bound up, and tried to see if moving the window tracks would help anything but its still stopping 3" from the top. Anyone ever had this issue? At this point I am about to swap the factory regulators back in to see what happens but I really do not want to go through that crap now if I can help it. I think the seals are too tight as well but not sure...
