Power Windows 1995 Mustang Convertible
bobmcneal
Rainbow City, AL
Had driver side motor go bad and had it replaced.
They replaced the switch panel also said it was bad.
The problem now is if temperature outside gets above 90 degrees all stops working until cools down.
After figured that out the left rear window quit working.
Noticed when press the switch for that rear window the light dim and then for about 15 seconds none of the windows work.
After about 15 seconds all windows start working except for the left rear.
Looks like there is an issue with the module that controls all this?
Possibly in mean time the rear motor may be bad.
I have two of the 1995 mustangs and both had problems with power windows?
Any suggestions??
Thanks
:sad:
Speedymac
