PRO STARS ON A 94 COBRA HELP!!!!!!!!!!1
carbedcobra93
I have a 94 cobra I want to run weld pro stars. 15/10 rear wheels with 325/50/15 M/T drag radials. Has anyone run this setup? Also I want to run 3.5 wheels on the front. What all is need to do to fit these/spacer? :dunno:
ForcFed93
I'm betting you have to minitub the rear to fit those tires. Not sure about the wheel/brake clearance.
white98snake
a 325 is overkill man, get a 315 or even a 275 on an 8in rim and u will hook like nobodys business
badass98svt
i've seen 335/17s on a mach with zero clearance issues.
you will need a 1/2" spacer to clear the calipers out back
if you plan on running 15s up front, you need a 3/4" spacer.
if you have a problem fitting the 325s, flip the quadshock upside down or just delete them all together.
ForcFed93
It's the height + width combined. 325/50 is a huge tire. I think like 28-29".
badass98svt
my 295/35s are 28"
plus, while it would be a 50 series tire, its on a 15" wheel.
ForcFed93
badass98svt said:
my 295/35s are 28"
295/35/18 tires are 26.1". 325/50/15 are 28".
97cobrasvt
hey I installed a set of pro stars on my 97 cobra on the front you will need a 25mm spacer per side witch you can buy at summit racing and the tires I run on back are the MT DR's 28 by 15 witch is 275.60.15 hope this helps
Z28 This
pics pics pics pics ;D
+1
95whitevenom
ok to slap skinnies on a cobra you will have to get a 1" spacer and also do some grinding on your caliper so the rim won't hit. Its really not worth it. A cheap and easy fix is to go get calipers,brake lines, rotors, and pads from an auto parts store for a GT and the fats and skinnies are easy from there.
The only other option is to get bogarts this way you ain't got to do anything but throw them on. no modding required.
Julian Moore
I run skinnies on the front, one inch spacer, no grinding on my cobra brakes. You may want to change your studs to three inches..not much thread to cath with the one inch spacer. Just a heads up.
badass98svt
julian, you don't use hub centric spacers? they have studs on them already
jarthur1995
