So I got a 94 gt and my speedometer, odometer, and tachometer all don't work. I believe that I should have a short or messed up wired somewhere, but can anywhere specify where? Also the battery power is very weak I know I have a parasitic drain somewhere, I don't know if this is just a cause of the short somewhere. Finally my lights inside the car don't work that also means the instrument cluster lights, when I turn on my headlights, at night my car is pitch black inside. I have changed the vss and instrument panel. When I switch the instrument cluster my oil and gas were broken and it did fix it, but the tachometer stopped working in the new one.
The main issue I have is just the odometer, speedometer, and tachometer. Everything else is just side information maybe to help resolve the issue faster. Thank you I really appreciate any feedback, I've fixed other problems in the car mostly mechanical but when it comes to electrical and using a multimeter I fail.
