Project-97
AStangThang
Ashland, Kentucky
What's up everyone, I didn't want to make this thread until I had all of my parts on hand and ready to go. Before I work tomorrow, I'm going by my machinest shop and picking up my heads. I've been collecting parts for about 2 years on and off for my PI swap. Here we go.
-ATK/SPARTAN remanufactured NPI 2v 4.6L short block w/43k miles.
-Ford PI intake manifold w/coolant mod-New
-C&L intake plenum-New
-Accufab 75mm throttle body- purchasing next week.
-2006 Romeo 2v 4.6L PI heads decked .030, factory exhaust valves, factory intake valves decked .040, Viton valve seals, PAC valve springs. Heads had 33k miles before I pulled the engine apart. Very lightly home ported and CC'ed by me, leak down was done by Randy my machinest when he performed the 3-angle valve job.
-MHS Gen2 Stage2 cams 224/226 - .555/.535 - 110/113 centerlines - 111.5+1.5 LSA-New
-ARP cam bolts-New
-Trick flow adjustable crank gears-New
-Ford factory head changing kit, head gaskets, exhaust gaskets, TTY head bolts-New
-Ford steal chain tensooner and guides-New
-Ford Motorcraft spark plug wires-New
-Ford Motorcraft spark plugs SP-432-New
-Elderbrock high volume water pump-New
-Mishimoto 2 core radiator-New
-Ford 170° thermostat
-Steeda aluminum clutch quadrant-Already installex on car.
-Steeda adjustable clutch cable-Already installed on car.
-Ram OEM clutch kit.
-National Throw out bearing, pilot shaft bearing,
-t45 input shaft bearing, output shaft bushing and seal-New
-Stifflers transmission crossmember-New
-Ford Motorcraft t45 cobra spec transmission mount-New
BBK Long tubes- purchasing next week
BBK x-pipe- Already installed on car
Flowmaster 44's cat-back- Already installed on car.
I'm sure I've forgotten something else, but it will come to me in time.
Burninriverdiver
Sounds like a stout combo! Should make a fun ride when it's all together. Any expectations/ goals you're aiming for as far as HP or torque?
AStangThang
AStangThang
Ashland, Kentucky
Thank you my friend, I'm definitely expecting over 300rwhp. With 300 RWHP and the weight of my car at 3290 with me in it, should make a decent little combo on the street. Thanks for your kind words.
d.garza18
TEXAS
Nope
Dang. I was talking to him via text, then he just stopped. I still owe him for the cams and chain guides but he hasn’t gottten back with me Incase worried about the guy
Addicted
Kentucky
I found my old build thread haha.
Alright, back to buisness. I took a few to read over what ive listed, and a few things have changed.
- My heads are done, vacuum tested at 28-29" of water, they're 2006 castings from a P71, factory valves with 3 angle VJ, radius exhaust, decked .012", slight port work, took .045" off intake valve margin. My combustion chambers CC'd to 45cc's on the dot.
- Bought a set of used Kooks long tubes
- I bought a complete B-Headed engine, but I will be using my .020" over NPI block (50K miles) for this one.
- I'm still using my MHS 224/226 cams, I will be installing these at 106 ICl
- Pac springs and vitons seals
- Trick flow crank gears
- I will be selling my bullitt intake and accessories since I'm not running turbo. I have a new PI intake that I will be using. Just a quick refresher. I will get pucs up tomorrow before I get yelled at lol.
evilcw311
Most Evil Member!
Louisville, KY
Found him!!!! Here he is, just under a new name!!!! [emoji38]
@Shaggy get in here and help this guy with the names or merging since I can’t!!! These freaking handcuffs are too tight!!!! [emoji1787]
Addicted
Kentucky
Good morning to everyone. It's pouring a rain here, my sinus headache has worsened, but want to give a shout out to some good peoples, evil, garza, blak, white, and burningriver for the good words and the welcome back. I truly appreciate it greatly, thanks again! I was shocked to see my old thread still here. She is currently in the garage at my dad's house ready for surgery. Me and the old girl has a 17 year love affair. So it begins! Lol AGAIN!
TreeScholar
