I spent a bit of time today trying to find the location of the belt squeel and finaly got the piggy to squeel. Seems the Previous owner(s) thought it an Awesome idea to only put two of the three AC compressor bolts in. This allowed the compressor to tilt downwards throwing the pulley alignment off. So i removed the bottom aft bolt and put it in the top bolt location (the one with a locator dowel). Instantly the belt squeel was gone.... At idle. Its still present at upper rpms With no load, so im going to look tomorrow for a replacement bolt locally.
I then got bored and started looking at some of the body work that needs done. The roof above the drivers sun visor was dented, so i figured that was a good place to start
Before:
As my luck would have it, the cracked paint line with the little bit of surface rust is the edge of the roof panel reinforcement. So getting infront of that area to work the dent out would be difficult, so i started behind it. After about an hour with a Body hammer and some highly custom body dollies (ground brass bar and some flat headed screwdrivers, this is what i ended up with:
Due to its location with the reinforcement panel, i doubt it could get any better, even with a stud gun and puller, so im going to call it good for now. Its pretty shallow (less than 1/8") so when it comes time to paint (im likely going to color swap the entire car), i'll just throw some reinforced mud on it and call it good.
