Project TRD Pony (Bar'd 2jz Swap)
Spd0lit
SoCal
Finished molding the vent into the stock hood and added aerocatch latches. It will look a lot better once the hood has some color on it.
Lanter
Indiana
Very nice! You leaving the latches black or painting them to match?
Spd0lit
SoCal
I'll be keeping them black, but the car won't be either of those colors when I am done.
wmfateam
Gilbert, AZ
What/where is this vent from? I was going to go basic and just cut a hole with a small flap in front of it, but this thing looks perfect.
Sent from my XT1254 using Tapatalk
Spd0lit
SoCal
You can find the vent from ken suen at bigredksr on instagram. I don't know how the fitment would be on a normal mustang engine bay yet. I might try the hood on my brother's 94 procharged car, but with the 2jz it might fit differently.
Spd0lit
SoCal
Well, I have wrapped up the intercooler endtanks and have finished mounting the intercooler to the car now. While the endtanks might not be twins turbo quality, I can say that I have learned a new craft and they should flow pretty well. The core is a garret 12x24x4.5
Spd0lit
SoCal
how did you make the ends?
Had this a few posts ago.
First rough cuts of the wood
Quick swipe through the bandsaw
After a whole lot of sanding and shaping I have the forms for my endtanks.
So once I had the wood form, i used it to hammer the sheet aluminum. I divided the tank into 4 sides and then welded them together. The hammering and welding was very time consuming, but I learned a new craft along the way so I found it useful.
Burninriverdiver
Thats awesome, they turned out great! That's cool you are able to do that from raw materials
evilcw311
Most Evil Member!
Louisville, KY
Let me first say that this is badass!!! But was there not a front mount that you could of bought already setup like that??
Spd0lit
SoCal
Most of the off the shelf intercoolers are only 3in thick, this core is 4.5in. And a lot of the custom built intercoolers have box style endtanks. Just after I finished hypertune came out with a cnc billet tank that looks almost the same. So if these ever fail I'll go with those.
Spd0lit
SoCal
Just finished up my intercooler piping and I am fairly pleased with the results. Moving that much closer to pulling the motor back out to freshen up and paint the engine bay.
DKblue98GT
That is some impressive work! I need you to come put a 2JZ in my 88 4WD Toyota extra cab...
Spd0lit
SoCal
That would be a pretty awesome swap! I heard that the manual 4wd would bolt up with the right bellhousing.
wbarter
