I am finally ready to dig into my engine swap and need to remove the old engine. I know it is illegal to vent the AC system to the atmosphere. I have a recovery tank, manifold set, and a vacuum pump. From what I have read, step 1 is to pull a vacuum on the recovery tank, then hook the manifold set to the high and low ports on the car, then connect the yellow line from the manifold set to the recovery tank. Open the vacuum valve on the tank and the low side on the car and the refrigerant should flow from the car to the tank. Sound simple but never done it before. The car doesn't run due and I don't want to haul it to a shop but I also don't want to break the law if possible.
As always - Thx
EWB
As always - Thx
EWB
