So I just got my comp cam http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=1062&sb=2 I have 1.7 roller rockers so it will be a .544 lift I am concerned about the piston to valve clearance. I will check but do you guys think it will fit in the stock bottom end 1995 5.0 with gt40 heads?
Duration matters more than the lift does , the amount of overlap. Is the camshaft degreed in? What's your lobe separation ? The small valves on the gt40 heads you should be okay but always check it for good measure . Hope this helps God Bless! Sent from my iPhone using Tapatalk
