Pulling the engine dude! I know its an absolute headache to think of, but long story short, youll be pulling it anyhow. We all here to coach you on when their are questions or challenges but honestly youll save more time by just doing it right
PREACH!! Exactly what I'm saying! Do it right the first time! No builder or mfg can tell you if your gonna have sufficient PTV clearance it's impossible for them to say so without seeing it and measuring it firsthand. It's like setting the timing every engine is different and the same principle follows with PTV clearance every engine is different! You always want to measure twice and install once because it is so much work to have to go back and redo things you rushed through just to get it done when in reality your setting yourself up for failure by rushing and costing yourself even more time in the future!
Tear her back down bro and get her figured out so you don't spend money guessing and possibly ruin your engine in the process! if you need any help at all were all here to answer your questions and help walk you through anything you may need help with or have questions about! Good luck on her bro and take care!!!
I understand what you guys are saying, and I was just going to buy the bore scope to look in at the cylinders to confirm I had ptv contact.
But I did a leak down test, twice actually because I didn't believe it at first lol. None of the cylinders lost any compression at all, which is a good sign.
I was also doing some research and I am being told that comp grinds these cams already with a 5 degree advance, can someone explain this to me? And why they would do this in the first place?
By using special timing sets, you can change the angle of the cam relative to the crankshaft. Spinning the cam forward so that the valve opening events happen sooner is called advancing the cam. Retarding the cam is just the opposite. Most camshaft manufacturers grind in around 4 degrees of advance into their cams so that it is automatic when you install your cam with the zero marks on the timing set. This is very common with street cams but varies with different race cams. Make sure you know what you have.
"Typically, engines respond better with a few degrees advance," Godbold explains. "This is likely due to the importance of the intake closing point on performance. Earlier intake closing leads to increased cylinder pressure and better responsiveness." As a general rule of thumb, advancing the cam will help low-end torque, but if your engine is dying by the flag stand, retarding the cam a few degrees should help extend high-rpm power a bit.
Read more: http://www.circletrack.com/techarti...n_science/printer_friendly.html#ixzz3ACHGYAbl
By the way the 270H and other Comp Cams grinds are manufactured with 4 degrees of advance.
Hope this helps you friend!
Your very welcome! Glad that helped you out friend!
Yes , the cam card that comes with your camshaft gives you all the information you need in order to degree the camshaft properly. Although you don't "have" to degree your camshaft for things to work I didn't degree mine and I know a lot of people don't and haven't that have built countless motors. But hey if you got the camshaft degree tool and the cam card and want to do it then I say go for it.
If you have any other questions friend don't hesitate to ask.
Are you going to use the Plato method to check the piston to valve clearance?
Good luck and take care friend,
