question about vac lines/catch can with a vortech system
rz5.0
Great state of TEXAS
that's how I plan on running mine on the 98.. instead of turbo it be a SC
Enviado usando mi SHP-L710 usando TapaTalk
damnit man as soon as I get out and get ready to snap my nearly 60 straight hr span of no sleep/all interenet/hospital stay to go into hibernation to catch up you do another 4 posts....
Thanks again.
rz5.0
Those inport guys have more info on this than any mustang site I have seen
we should fix that. I will try to separate portion of my build off in a separate page for future use - if I ever understand it enough to try and teach someone.... :) Not there yet by any means.
bhorne89
Kansas City, Mo.
If it helps I ran -12an hose from each valve cover to a breather catch can. I had to have a guy weld on the male -12 fittings to the valve covers. Came out nice. I plugged the PVC on the intake. Set up is Dart 408, with a Procharger. I will try to find the link to the breather that I used, it had two -10 or -12an available.
ok that was my next question was how do I get the -an fittings on the valve covers. I have only started to weld last year and just barely got into aluminum so not sure I want to try this myself. Is there a different way with out welding? If not I will figure a way out but just checking.
bhorne89
Kansas City, Mo.
I have not decided on valve covers yet other then they will be blank/back so I can put the fender badges I had made on them after chroming them.
marktuck99
