Ran at englishtown tonight.. heres the results
ReVz
I ended up running both my cars tonight
2004 ran 14.4 @ 96
1994 ran 15.1 @ 91
Another problem im having is tho in my 5.0, the throttle keeps stickin.. what could be causing this.. and would of had a major inpact on my time? I feel like i could of done a whole lot better wit my 5.0... did I do good or bad? A little help please. I gotta fix that damn Sticking problem
94gtstang50
I'd say thats a decent time, probably could have been in the 14's if the weren't any problems but still a good time.
R
ReVz
Its just so much harder to push the pedal down. And my boy said its sticking to.. its just getting worse an worse.. is it something wit the cable?
jimgt95
I would say, disconnect your throttle cable and spring at the throttle body. Pull off your CAI so you can see into the TB. Grab the throttle linkage on the body and move the blade from closed to full open several times checking to make sure that there is no interfernce or sticking. If it looks really dirty, buy some carb cleaner and clean it up. If everything moves/looks ok on the TB end, then I would start to inspect the springs and cable for wear or dirt (or a pinch point in the engine bay) that could impede their movement. If they look ok, then I would take a look at the pedal assembly itself because there may be something caught in the pivot points or they may need a quick shot of lubrication. Let us know what you find.
Addermk2
Ive got a stock cobra TB that ill send out to you.... gimmie $10 and pay the shipping
sound good??? ill get you some pics if your interested
R
ReVz
I got a 70mm TB on. I just put in on a week ago. The Throttle is just sticking on me. Its something wit the stupid cable
RobertC
