I have 97 vert and I hear a noise in from the rearend. it seems to have something related to the rotation of the tire, almost like metal/metal grinding....just change the bearing and axles and still have the same sound....any help is appreciated....thanks
Did you put in new axle bearings? I didn't quite understand your post. With any kind of mileage, you should replace all bearings races and seals when you have it torn apart. Did you upgrade axles? Are they used?
Put in new axle bearings and axles new.....I will be doing gears and all diff bearing next and hopefully it will fix the noise....the brakes still have about 60% left....
