Rear Seats
CanaryGT
Phoenix
Is there an easy way to remove my rear seats?? I couldnt find it in my Chiltons Manuel and im confused. Can someone enlighten me???
Lightning Struck
I wouldnt call it the easy way, the only way I know of is to remove it all :dunno: You have to take out the frame and the top piece of the trim just above the seat as well as a lot of bolts n such. Anyone know of a better way ???
ryclef331
I assume you're talking about the lower cusions. If you get in there and feel between where the seat means the frame rail, you'll find a white plastic latch. You push in on the front of the white plastic tab and the seat should "pop" up. Do that on both sides and that bottom cushion will come out. The back cushions just unbolt. If you're removing them, its the framing that weighs the most on the seat backs....
CanaryGT
CanaryGT
Phoenix
Yeah im removing them to dynomat the car and I wasnt too sure on how to get them out. Ill give that a try when I get a chance and get back to you. Thanks for the advice!
mattn03
