Rear View Mirror
Toffels
Kansas City
I have a '95 GT and recently the heat caused my rear view mirror to fall off. I managed to get the metal button out of the housing on the actual mirror and have the button glued back on the windshield. As far as I can tell the button is in the correct orientation (the rounded end is nearer the roof) but I can't get the mirror back onto the button. I'll try to slide it down from the top and it'll pop right off. I have a feeling there's some spring steel in the housing that helps hold the button in place as I had to use a screwdriver to bend the bottom of the plastic housing to remove the button, but I'm having problems getting leverage to do that while trying to reattach the mirror. Does anyone have any tips or tricks that might help? I can always take it to a glass place and ask for help but want to avoid looking like an idiot if there's a simple fix I'm just overlooking.
RossA81
Monkton, MD
I had to very carefully tap mine back on with a hammer and a block of wood; all the while trying not to knock the freshly glued button off the windshield. It was a delicate "little bit at a time process" The mirror needs to fit all the way onto that button and its a tight fit. Good Luck!
Ross
COBRA_ESQ
Long Island NY
If it is like most (all?) rearview mirrors the button edge slides into a slot in the mirror mount. I suspect it isn't going on because either the wrong side of the button is glued to the windshield, or you are not flush with the windshield when slipping the mirror on. As a last resort maybe buy glue kit and a new button and glue it to the old slightly lower.
qzxo_oxzp
