right pi intake
samsonhusky
I'm looking at getting the opr replacement pi intake w/ gasket set that is on american muscle. Is this basically the same as the ford performance pi intake just another brand and will it work with the npi heads like the ford racing one ? Plan on getting it for my 96. Thanks for the answer in advance.
https://www.americanmuscle.com/pi-intake-manifold-9904gt.html
PinkieT
Cleveland
The one at American Muscle looks like the Dorman aftermarket intake. https://www.dormanproducts.com/p-30036-615-178.aspx. My opinion is that it will work, but with a smaller plenum and different runners you would lose power vs. the FRPP piece. I have a nice FRPP PI intake I would sell you for $150 plus the ride, you would just have to drill and tap the hole in the coolant crossover for the sensor by the thermostat. You could probably use the thermostat and housing off your current intake. PM me if you want pics of my intake.
96blak54
In the shop
To bad i can't just wheel a box of these frpp pi intakes here at my job. Pass them out as sn95forum gifts. I look at theses things every single day!
mikeetown89
I recently did the swap on a 96 Mustang.
Don’t go Dorman, it’s a waste of time and doesn’t work cause of thebgaskets. you can make it work but why would you. You are already making a modification to the FRPP one with a gasket maker. Just spend the money, the power difference was amazing. I notice it every day without a tune!
mikeetown89
The info I had.
Parts needed for mustang for swapping onto a non PI 1996 4.6 2V
Two O-ring Gaskets - Heater tub Nipple
Part # (Nappa)
Mahle 72014
Part # (ford)
391533S100
  • Coolant Heater tube Nipple (twin O-ring) Part#: F75z8555aa (ford genuine off AM.com)
  • Can use a generic O-ring that are 49 cents each
Intake Manifold Gaskets
  • What I got, MS 95728-2. This is plastic (it will work, just make sure it’s for a 99-04 mustang)
  • What I need MS 98007 T-1. Steel Heavy Duty!***
-Ford Air Intake Manifolds
non PI Dorman
615178 (junky)
- PI Dorman
615175 Does not improve HP
-Ford PI Made by FRP**
M9424P46 <— what you want
HVAC Heater Pipe MOTORCRAFT Part#: KT-21
fits 99-04 Ford Mustang 4.6L-V8
Get the coolant nipple from ford if you need it
  • This part is the coolant crossover needed for under the new intake to make room between cylinder heads
For making heater temp hikes in crossover
3/8 Tap (NPT type)
37/64ths drill bit
NOTE:”“Took a bit to get it installed on my non PI heads, definitely make sure you have the 99-04 coolant fitting and pipe that runs under the manifold as well as a 37 64th drill bit and taps if your converting to a non- PI motor, as well as the 99-04 gaskets which you'll want to use a bit of RTV around the coolant ports, as you'll notice a difference between the gasket and the ports.””
Injector service video
Thermostat for car
188 - 33029
180 -
Fuel Injectors
F1ZE-C2A 86-95 mustang 19lbs/hr rating
laramik
The info I had.
Part # (Nappa)
Mahle 72014
Part # (ford)
391533S100
non PI Dorman
615178 (junky)
- PI Dorman
3/8 Tap (NPT type)
37/64ths drill bit
Thermostat for car
188 - 33029
180 -
Fuel Injectors
I thought it was best to use the non PI gasket set in order to avoid vacuum leaks?
Sent from my SM-G960U using Tapatalk
laramik
PM sent if OP isn't interested I'll take it.
mikeetown89
I think the intake manifold gasket part #’s above might be non PI, my bad. But, you need to use PI gaskets. The plastic intake requires square gasket. I have no vaccine leaks either.
Cwacaser
