Rio Red 98 GT Build
lwarrior1016
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Finally found time to work on the 6r80. All the clutch packs are built and the internals are installed. I have to assemble the pump and valve body tomorrow. Then, it is ready to go in. I don’t believe I’ll be getting it installed though, we had some pretty heavy rain all day today and the ground is soaked. I guess we will see where tomorrow takes us. Who knows, it might end up with the headers and transmission final installed tomorrow.
lwarrior1016
lwarrior1016
South Mississippi
So yeah, here we are two months later, and today was the day I got the transmission installed. I fought pretty good with the passenger header. The header had to go in, then the starter, then the flywheel, and finally the transmission.
In fighting with the header, I trashed one of the composite gaskets, so I got a set of MLS gaskets. A05E0454-D676-46E7-AE6F-32BE68A446DB.jpeg3E95B6F7-E3F6-471B-81E0-93C17E9E71DF.jpeg1ED0DB94-B3BD-45A3-8954-4B6F6B0B0A2B.jpeg
Got that ready Sunday and Monday evening. Then today I was finally able to find time to install the transmission. 39FC56E5-B3BF-41F0-975C-9DA8DD4A4D04.jpeg465125EB-B0AB-4728-A058-8CB48853D19C.jpeg6E090DF0-CD8F-4247-820A-B6326DFDE0EC.jpeg
joemomma
That looks like ZERO fun in a gravel drive. At least it looks to be mostly what we call "river rock" and not granite.
Musturd
Fuck motivation would be at all time low with the gravel driveway . I remember pulling the drivetrain outta my fox gt in my old gravel driveway and it was like pea gravel . Wanted to shoot my self
lwarrior1016
lwarrior1016
South Mississippi
Spent a few minutes in the car today. I removed the trans tunnel hump I installed not long ago, and began test fitting the Lokar shifter. I have to make a plate to mount the shifter, and some tactical cuts in the center console to clear the shift cable. C7E87E22-6CA0-40C6-941A-96EB4A895A3A.jpegEF48CD33-F691-4B7A-9426-D2F8EA96557B.jpeg
Then I pulled the driver seat out and began brainstorming a way to mount the s550 seats.
Bottom of the s197 seat with manual SN95 tracks 55C5A337-485F-46C4-BD54-02775D727D0C.jpeg
I started with cutting the tabs off the s550 seats. It’s crazy how these tabs are not very secure on the stock rails. A couple of really small laser welds. 45seconds with the cut off wheel and the tabs came off. D6598E15-C808-43F0-9319-DA6E5825A807.jpeg
I’m thinking I’ll be able to cut the sn95 tabs/mounts off and weld them to the bottom of the s550 rails.
joemomma
Could you just move the SN rails over, or are you trying to save the power functions?
lwarrior1016
lwarrior1016
South Mississippi
The sn rails are nowhere close to fitting on the new seats. The way the power rails mount up it’s completely different and the width of the new tracks is different as well. So, I guess I’m keeping the power lol.
RAU03MACH
NEW MEXICO
i know if i try that set up later down the line i will shit can the electrical parts and use the rails to bolt in ,
RAU03MACH
NEW MEXICO
In fighting with the header, I trashed one of the composite gaskets, so I got a set of MLS gaskets. View attachment 23075View attachment 23076View attachment 23077
Got that ready Sunday and Monday evening. Then today I was finally able to find time to install the transmission. View attachment 23078View attachment 23079View attachment 23080
i still say that scares me, i need solid ground
lwarrior1016
lwarrior1016
South Mississippi
So, today was an alright day. I made a plate to cover the old shifter hole and to mount the Lokar shifter at the same time. Put a few tack welds on it then riveted the plate in. Covered the seam with some heat/sound barrier.
Then put the heat barrier all under the car in the trans tunnel. Got up on the firewall some too. Trying to minimize heat on the floor from the exhaust.ACA25B22-52CB-4B95-8FC4-7AAAC30CC46C.jpeg
Also installed the driver side header and steering shaft. 09ECF4A1-63FF-4292-84D9-1EB34D7DA4C3.jpeg
Then drilled some holes and put in riv-nuts to mount the shifter. D9C592CB-A0E3-4610-A517-8CFD7DD8F6C7.jpeg
lwarrior1016
lwarrior1016
South Mississippi
So, I’ve been chipping away at it slowly. I ordered a replacement gauge bezel and painted it grey. I like the contrast, and I feel like it matches the passenger side better now. B1E3C198-52DF-42E1-A5F7-0BA24C33186C.jpeg1DA73C29-7631-46E0-BAB9-0C91772AD58A.jpeg07515E85-91D1-4BA4-AEF1-3B1ADFD410EB.jpeg
I also had to cut the cup holders on the center console for the shifter cable to clear. I’m going to shorten the front holder and epoxy it back on. It’ll be a change holder or something. The rear slot has the insert that goes in, so it’s still completely functional. 29F5A6E7-8E86-44CE-84DC-DE5CBE3236F6.jpeg
I also got my Fathead Garage A/C kit that moves the drier and lines in to the fender. Been fighting supply chain issue on this one. I ordered this in July-august of 22 and just got it a few days ago. 5791B7EB-AB33-4191-A0B3-99A962D425A5.jpeg
lwarrior1016
lwarrior1016
South Mississippi
Been slowly picking away at it. Today, I finished up a bunch of wiring, and I put power to the car. This was a HUGE step for me. I built and wired in a fuse/relay box and that all works so far. Then I plugged in the laptop to pull the tune file out and make adjustments. I also verified the electronic throttle works and the throttle body moves. Still have a bunch to do, but it’s much closer now. 927BC3AD-6355-40A1-987B-1004F9A11161.jpegA3F975FE-420D-4B64-AA50-A581850E614E.png
TN95gt
