Adam Vinnicombe
- Joined
- Jun 28, 2019
- Messages
- 498
- Reaction score
- 71
It only happens when I'm crusing at a steady speed, if I accelerate or decelerate even a tiny bit it stops.
Change the preload on the throw out bearing and see if the RPM range changes.
Hi all well it went to the garage and they had a look at the car. Oil drain and filter cut open and nothing found. They then played around a little more and although they could hear the rattling sound they were not convinced it was coming from the engine. They dropped the idle down to 400 rpm and the rattling sound was bad but its the clutch release bearing, as soon as you push down the clutch pedal the noise went away.
I will be posting two videos. One is of the rattling sound when playing with the rpm and the other is the rattling sound when the idle was dropped to 400rpm
Yep they quoted me £950 ($1200) to do the job
Out of interest what should the safe idle be?
We found out that although it would idle at 400rpm it was happy when we loaded the engine by turning on the AC. It seem pretty happy at 550rpm. They did say my ordinary idle was to high which was 925 ish rpm. They have set it to 800 now
The car has a diablosport 93 octane tune on her.
I will look into the settings of the tune once I find out how to use the little iPhone size handheld device
I increased the preload on it and the rattling sound came in higher up the rpm rangeChange the preload on the throw out bearing and see if the RPM range changes.
