scarface
Guest
I would check the wires, and replace the sending unit. If that doesnt do it, get a manual gauge and see what its doing.TheBab said:scarface said:so the main problem you were having is gone right ?TheBab said:I'm spinning 1st, 2nd, 3rd with newer BFG Geforce Sports ... 275 wide. :hammer:
:thumb: :thumb:
Ordering my XCAL at the end of the month and HOPEFULLY hitting the track up with my et streets the first of July...
I want to hit in the 11s.. I'd be happy with only running 8-9 psi.
I have zero problems... the car runs better than when I first bought it.
Actually, I do have a question.. my oil gauge on the cluster... It can be sitting at normal and if I floor it.. it'll drop... not all the way but drop or bounce around while normal driving... is this due to an old arse gauge? Should I buy a good autometer oil pressure? gauge....
I check my oil just about everyday .. lol.
(I need to replace the oil pan gasket so it has a SMALL SMALL leak) but I like to check the oil all the time.
It's pretty much at the Max line on my dip stick.. but yet I can floor it and the needle goes ALMOST to the Low reading.
