Speedstang302
- Joined
- Mar 2, 2010
- Messages
- 126
- Reaction score
- 0
hey guys so maybe some have heard i parted out the blue car and scrapped the body...so pretty much everything is for sale...its was a fully complete 96GT 2v...i have everything PM w/ needs..i prefer local sale i dont really wanna ship stuff..i work 5 days a week and 15 hour days...last thing i wanna do is deal with shipping (when i work for ups all day :dw ill ship small stuff...really anything over 20lb's unless you wanna pay FULL shipping cost..ontop of my asking price...let me know worst i can say is no..for now that could change...
heres a small..yes small...ive probably got 2x this amount i just cant remember everything
npi block w/ 115k and still have very clear crosshatching- $100
npi crankshaft- $50
npi connecting rods- $30
npi pistons- $30
npi oil pump and pickup- $30
low mile 4.6 oil pan w/ no rust or dents sprayed high temp RED- $100
npi cylinder heads w/ 115k- $50
2 sets of lash adjusters- $30ea set
2 sets of rockers0- $30ea set
npi cams- $30
pi romeo 2002 cylinder heads (w/ valves, springs, slightly ported intake and exhaust ports..mostly just smoothend out not polished)- $300
pi romeo cams from a 2004 w/ 42k miles - $75 **SOLD**
comp cams xe270ah camshafts new/used...they have never been run, just opened and laid i heads, never even torqued down- $450 **SOLD**
4.6 2v timing chain setup (comes with iron (not plastic ones) tensioners, guides, chains minus cam sprockets)- $100
pi romeo 11 bolt valve covers sprayed high temp wrinkle black- $100
npi timing chain cover in AWESOME condition paint high temp silver- $100
npi power steering resevoir bracket (heavy duty one for coil pack setup)- $25
pi power steering resevoir bracket (lightweight steel one for cops)- $15 **SOLD**
npi power steering resevoir- $10
npi alternator worked perfect- $30
npi radiator cooling fan (electric)- $20
motorcraft coil packs w/ about 15k miles on them- $40
ford racing 9mm spark plug wires about 5k miles on them RED- $50
pi intake manifold w/ aluminum crossover and 2nd temp sensor already tapped and in (for 96-98)- $100 **SOLD**
pi coolant crossover tube and pi water pump nipple (needed for pi intake on npi motor)- $20
stock pi intake plenum w/ bbk 70mm tb and newer iac and newer tps- $150
new 96 throttle cable (extremely hard to find)- $25
BBK longtube headers for 4.6 2v (they were ceramic, now painted high temp silver, few small dents)- $325
BBK catted x pipe (painted high temp silver)- $225
SLP LM1 catback complete- $350
COMPLETE a/c system including lines, condensur, evaporator, compressiosor all worked and didnt leak- $100
COMPLETE car wiring harness..i have every single piece of harness of an 96...from front to back top to bottom...let me know with needs..also have a perfect working 96 computer
power steering rack in great condition- $60
power steering shaft w/ very little play- $20
power steering pump- $20
new replacement 94-98 outer tie rods- $30
new replacement lower balljoints- $30
prothane poly 96-04 4.6 motor mounts brand new never seen road- $100 **SOLD**
96-04 steeda strut tower brace painted wrinkle black- $100
tubular upper/ lower rear control arms w/ new hardware- $80 **SOLD**
94-98 8.8" rear end w/ stock 3.27's, new lucas dif fluid, dif worked mint and upr spherical bushings- $400
stock 94-98 driveshaft- $30
94-98 brake master cylinder, hydroboost module, calipers, rotors front/ rear let me know what you need..cheap could use for cores for guys doing fox 5lug swaps
STOCK T45 TRANSMISSION w/ about 80k miles on it, does grind any gears shifts fine- $600
black dash in great condition- $100
steering column with black steering wheel w/ airbag- $150
clutch pedal assembly- $40
black center console with cupholders- $75
black leather rear seat setup- $100
black rear headrest- $30
black non mach 460 rear speaker deck cover- $20 **SOLD**
black 460 rear speaker deck cover- $30
black 1/4 panel trim- $30ea
black 1/4 window trim- $20ea
black a pillar covers (have multiples of each side)- $15ea
black headliner in MINT condition- $40
black visors in MINT condition- $30ea **SOLD**
passenger black door panel- $50
grey door handles- $30 **SOLD**
black door handles- $40 **SOLD**
black door cups- $25ea
**NEW********
HO fibertrends 3.5" fiberglass cowl hood w/ rear vents- never seen road once- $400
Kaenan s281 saleen fiberglass spoiler- new never seen road once- $200
kbd polyurethane saleen door fillers - new never even opened- $200
1pc headslights black background, amber corners, clear lense- brand new- $100
96-98 taillights smoked, i mean BLACK w/ black bezels- $100
**NEW********
new drivers front fender- $100
new passengers side fender- $100
new inner fender liners- $60- **SOLD**
new gt front bumper w/ small tear- $50
used gt rear bumper- $50
(2) stock gt spoilers 1 black 1 blue- $30ea
94-98 decklid w/ spoiler holes- $100
drivers side 1/4 window in mind condition- $40
1/4 panel side scoops- $20ea
mint drivers door w/ power everything- $100
mint pass door w/ power everything- $100
new front impact absorbers (accordian pieces on core support)- $30
new front crash bumper (metal piece)- $50
new front crash bumper (foam piece)- $40
new headlight mounting bracket- $50
prices are obo not firm but dont try and low ball me on this stuff..i wont even respond to you...
i took every single nut, bolt, bracket, piece of wiring off the car..so if you need anything just ask...
[email protected] for fastest response...i can get pictures but may take some time since 1/2 the parts arent at my house...
thanks! :beer:
npi crankshaft- $50
npi pistons- $30
npi cams- $30
**NEW********
**NEW********
thanks! :beer:
