Shorty Equal length headers
95Grandtouring5.0
Will they bolt up to my stock h-pipe? What brand do you recommend? And does it make any difference in the tone or db of the exhaust?
ryclef331
Yeah they'll bolt up. You won't notice MUCH of a tone change being that you want to retain your stock h-pipe...I'd suggest a catted mid pipe of some sort with 2 1/2" piping....you'll be choking the car and not taking full advantage of the headers.
94yellowgt
If you are mostly stock, I would not recommend putting them on because they are a PITA to get on there. It took me 5 1/2 hours to put mine on after I got the h-pipe unbolted. If you plan on doing heads at some point, I would wait until then because they would be SOOOOOOOOOO much easier to install.
Anrev
Especially if the exhaust has never been off. I had to sawsall my h-pipe in to chunks to get the stock header to come down enough to cut the bolts off at the header flange. My shit was rusted SOLID. Im going back on with stock shorties, Jegs O-R X-pipe and FM cat-back. When I need to get emissions done in 2 years Ill switch to full length headers and cated X-pipe.
Brian95GT
Steve-Oh said:
Long Tubes FTW!!!
Same here. I had MAC equal length shorties, and thank God I changed out to long tubes. I installed the LTs with the new motor so it was a breeze, but the install for the shories was like 6 hrs like stated before. Just spark plug changes are one of the perks. Even then, you could just go with unequal shorties and get an off road mid-pipe.
ryclef331
Shorty headers and shorty equal lengths are BOTH the same "overall " length.. I.e. they start at the head and terminate at the h-pipe. The DIFFERENCE between the two is an unequal lenth shorty's primaries tubes are all different lengths and just straight shots to the collector. Equal lengths, wrap and bend allover to make EACH primary tube the SAME length to the collector. The visual difference is obvious. Unequals look like stock but with bigger tubes. Equals look like a bundle of damn snakes.
Urban Legend
I put on BBK unequal length, and they went on great, except the gaskets they sent were junk.
socalsmith
