Sn953valve Build
ellerstang
Kingsville, Tx. 78363
originally a 95 v6 to 5.0 to a 4.6 3valve back in 2010. video is on you tube the first time i started it up
[video]www.youtube.com/embed/5f3f_VEwB_o[/video]
Ill add pictures tonight when i get home cant seem to uplaod any from where i am at
Ive been busy with it and decided to start sharing my progress.
I went ahead and put rear coil overs in the back from Team Z and mini tubbed it, also put a paxton 1200 sl on the 4.6 with a cnl manifold intake. front coil overs also. fuel cell in back with A1000. swapped out the stick to a built auto. went with a wolfe race craft roll cage. and currently right now the car is at the paint and body shop getting painted. i went ahead and changed it from black to the new grabber blue.
E
ellerstang
Before the build to the 3valve, the wife and 5.0 at the park
[/URL][/IMG]
E
ellerstang
the motor and c4 slapped together
the motor and tranny dropped it without the suspension in
the underside
the day I first turned her on, click on pic
D3VST8R96GT
Marble Fall, AZ
What long tubes did u run? Did u use 2v headers and 3v flanges or adapter plates.
I really wanna keep my return style fuel system
The D3V
E
ellerstang
I used the 3valve pacesetter long tubes and squeezed them in,
but now I am going with the 2v kooks long tubes with the adaptor plates
it is still in building stages right now its at the paint and body shop but the mini tubs are in and also the roll cage. body just needs to be put all back together
I just need to upload some more pic's but after I got the hole thing running again, I went ahead and stripped it all down and started building it from the ground up again.
E
ellerstang
The D3V
I don't know if you saw the engine pic but I do have a return style. I went with the feed in two a crossover and a return off the regulator back to the original gas tank, but now I'm going with a fuel cell.
punched281
Colorado
Bad ass car, definitely more pics and show this thing off after it is back from the shop and getting put back together.
D3VST8R96GT
Marble Fall, AZ
Nah hahaha I post almost exclusively from my phone so everything is a thumbnail quality
The D3V
KillNThrill24
Cleveland Ohio
Right on man you don't see enough 3v builds. I'd imagine with the oldest 3v being 9yrs old now that we'll start seeing more.
Interested to see what power levels you end up with
Sent from my SCH-I605 using Tapatalk
E
ellerstang
here is a pic of the mini tubs all done and rear floor put in with the roll cage
here is a side shot
the engine bay after blocking off the ac and heater ports
after paint
E
ellerstang
the back half painted after everything was welded
front suspension going back in
inside all painted
test fitting the seats
got the fuel cell in place
test fitting the new carpet
started to lay down sound deadner
E
ellerstang
got the motor loaded up to drop back in
and her heart is back in place
ill post up more on her progress when I get a chance again, got a few more pic's to upload
Mustang Mark
Good choice with the 3v definitely a strong engine stock with plenty of possibilities.
jarthur1995
