Solid Steering Rod?
NYC94GT
Anyone swap out the factory steering rod (between the power rack and sterring wheel shaft)? If so how does the car feel? Is the steering wheel pulled hard whenever you run over rough pavement? Vibrate??
Thanks! :thumb:
ryclef331
The only thing it would do really is give you a more solid feel with the tires. The stock shaft flexes....a new one won't. HOWEVER, a new steering shaft will NOT cure bump steer issues or vibrations.
N
NYC94GT
I already have the bumpsteer setup on the tierods, what my concern is how the steering will "feel". Is it going to make it feel like a truck? Or cause more vibration?
Thanks, :dunno:
ryclef331
it will feel alot better. Your wheel will feel more connected to the car....not like its pulling on rubber bands connected to the wheels.
95CALI-5.0
I have a solid steering shaft in mine. The steering is much more crisp. If you auto x or take your car out to the road course I would recommend one.
N
NYC94GT
How is it on the street? Is it harsh? I guess I shouldn't care because I am running a full Griggs setup... :dunno:
ryclef331
EVERYTHING will be improved! The vibrations you feel in the wheel are a direct result of a tire or wheel being out of balance....not b/c of a solid shaft. Your stock one is hollow and flexes....alot!
N
NYC94GT
Great, Thanks! :thumb:
95-stang
Any particular good or bad ones out there?
Looking to change mine in the near future.
