tvsn95
- Joined
- Feb 9, 2020
- Messages
- 136
- Reaction score
- 46
OK, I have postulated before and SOOO here I go.
60lb Siemens work great,( (American Made) the ONLY reason for the small injectors is that , OLD large ones were hard to get a clean idle. same can be said for the Chinese ching chong, stuff that some of the Big guys sell. Tech has come a long way but when you are spending 200-500$ for injectors get the ones that work FIRST. Remember, if you change injector the tune is also changed...sometimes very drastically. So do it once and done.
I put 60 Siemens in all the turbo and supercharged engines/cars that I build and tune... 302s and 351s.
you will make enough to destroy your car and wallet.
I make 750hp and am running 80% duty on mine. Mine is a daily street car, so drive-ability it keen. Also, I know I have said this before but when you boost you WILL run out of fuel system, the very min is an Areomotive 340lph. and you WILL need to up the lines. The rails will support 500 or so (SN95) NOT FOX rails.
Quantam sells an enlarged ,intank hanger with AN fittings. get one and install -8 supply and -6 return W/ a remote regulator, set to 40lb idle.
I run twin Walbro 255 externals. the car I am building now I am using an 400lph in tank that I have no experience with. I will learn soon if it works OK. LOL
