Are these hubcentric? Discount does not sell them. Tell me if these will work, please! Thanks!! http://www.americanmuscle.com/1in-billet-aluminum-wheel-spacers.html
I e-mailed Discount Tire and asked if they sold the spacers. This was my reply: Hello Eli, Thank you for your inquiry. unfortunately we do not sell or recommend the use of wheel spacers. It's been our experience that they cause vibrations and lug nuts to loosen up. Is this true? I am at a loss now! A lot of you have them, right? I guess they can cause this, of course. I already ordered mine from American Muscle though! Let me know what to do though, please! Thanks!
ya those are hubcentric. hubcentric you bolt the spacers to the hub using the factory studs and then there are studs on the spacer to bolt the wheel to. non hubcentric use the studs from the hub to bolt on the spacer and wheel so the spacer is just sandwhiched between them with not a lot of thread to bolt the wheel onto. that is when you will have most of your problems.
i believe the problem with some stockers is the back of the wheel doesnt have enough clearance for the studs/nuts that bolt the spacer to the hub.
