Speaker BUzz
Stangbangin
I had installed my aftermarket sony headunit that sounds good. Until you turn the car on and the engine is running you can hear a buzz threw the speakers. It's congruent to the rpm's so I'm assuming it has something to do to my coil or wires or something...both msd any ideas on what it is and how to get rid of it???
Matt94GT
Id say its a bad ground more then likely, or a live wire somewhere behind your headunit touching another or resting on some metal. Chances are its what I said. Or if you have any stereo wires running along side close to one of your MSD wires that could be the problem as well.
94gtstang50
+1 might be the rfi is worn out,(weird little cylinder thing attached to the coil by a screw with one wire coming out of it.)
Rsf1013
