J_lope82
I noticed my Speedo is starting to act wacky. On take off it stalls at around 10 then all of a sudden jumps to around 25mph. Any one experienced anything like this? Is my Speedo gear starting to go out? TIA
Lol I had to read it twice. Good one!I have always been more of a board shorts dude myself, not that I don't look KILLER in speedos IMO... But anyway, what year? Have you done any work on the trans or gauges recently?
What do I check for on the cable?Check your speedometer cable.
Pull, inspect, and lubricate it *now*, before it breaks!The difficulty with checking a speedometer cable is getting to the end that connects to the speedometer. The speedometer cable is a long flexible cable that is inside a long flexible tube connecting the speedometer to the transmission. To check the speedometer cable, once it has been disconnected from the speedometer you grab the end of the cable and pull it out. It is 6 to 8 feet long and you do not want to get it dirty. Once it is out inspect it for dryness, fraying, or breaks. If it has no damage, I usually spray some lubricant into the housing from the speedometer end and then reinsert the cable into the housing. If the cable has any damage, replace the speedometer cable assembly(the housing and cable together). Once the cable has been reinserted into the cable housing, gently turn the cable until the cable catches and goes the rest of the way in. If the cable goes all the way in but still rotates, there is most likely a problem with the plastic speedometer gear in the transmission.
