Spindle nut removal....?
G_94_T
TN
Im in the process of upgrading my front brakes to '03 GT PBR calipers.Since i have the stang in the air and the front tore apart i was going to go ahead and re-grease the wheel bearings but i've hit a snag.There seems to be some sort of metal "shroud" around the spindle nut.Does this come off with the nut or am i suppose bend the tabs back on it for some reason?.....Any help would be greatly appreciated.......thanks..........
ryclef331
Are talking about the metal dust cap? Just pop it off with a flat head. I think this is what you're talking about. I haven't taken my wheels off in awhile so I can't remember exactly but it SHOULD just pop off.
G
G_94_T
TN
no,i took the dust cap off and the spindle nut itself has like a sheetmetal "cover" on it........am i suppose to take that off....i assume its some sort of device to keep the nut from backing off because there is no cotter pin....
G
G_94_T
TN
as you can see in the pic,ive bent 2 of the tabs back trying ti figure the purpose...but anywat...........
[attachment deleted by admin]
G
G_94_T
TN
come on,surely someone has had to have changed a wheel bearing something
redripper
If there is no cotter pin the metal shroud around the nut is a keeper. If you bend it out you should replace because the bending back and forth will weaken it. SAFETY first im sure you dont want your front wheel to fall off.
BRAD
ryclef331
I wouldn't do that. Use the keeper its there for a reason. Red Loctite will let it go on but you'll NEVER get it off. The reason the keeper is there is to obviously keep that nut from backing off b/c it shouldn't have a very high torque setting on it. If its too tight, it will over preload the bearings and they'll fail early. I would fuck around with loctiting it. If the factory put that on there, I'm pretty sure they knew what they were doing.
SN-95
yea its all one piece and u cant regrease them they are sealed up.... all u can do is just take them off and put a new one on... by the way dont mess them up cause they cost a nice penny for them i remember paying around 140 per side...
Br1anh
