hechtrod said:I'm in Utah too and if I keep my stang for the long haul, I want/need to do a rebuild. Because of budget and goals for the car, I think all I'd do is a 306 with nice pistons and rods. What machine shop did you take the block too? How much did the block work cost? Did it include clean (hot tank?) and paint? It looks great by the way.
Can't wait to see how everything turns out. What intake are you running? I didn't see if you were going to use the Cobra or a new one?
I'll be watching this closely. I too would be interested in knowing what the final cost with a break down ends up?
Thanks,
Chris Hecht
The machine work was done by a local shop here, Pro Machine. They do really good work, and they were really fast with my stuff, so i have no complaints.
Machine shop costs:
Hot tank
Replace freeze plugs and oil galley plugs
bore 8 cylinders with the use of a deck plate
Install cam bearings
polish crankshaft
radius oil holes on crankshaft
(1) set of SRP forged pistons
assemble pistons and rods.
Piston rings
Rod bearings
Mains bearings
Rear main seal
shortblock assembled
and i and i had him order my head gaskets as well, which were 160 bucks
But, all of that for a little less than 1700
The damn pistons were almost 600 themselves.
Dalamar and i painted the block, so that was just the cost of tape and a can of paint.
I will be using the stock cobra intake for now, but i intend on upgrading in the near future.
Hey Hechtrod, are you wanting to add boost or nos when you do your rebuild?
