Installed upper and lower today. SR Performance from American Muscle.
I had the necessary tools, air tools and a helper.
Install for all 4 control arms, shocks and removal of the quad shocks and mounts ran 8 hours.
Ran into problems reinstalling the sway bar. All the instructions and videos I watched stated that the sway bar installs on the inside of the brackets. The SR sway bar brackets are welded on the bottom of the tubular bar and sit lower than the oem mount.
No way my factory Cobra sway bar was going to fit between those brackets. I ended up installing the clips on the control arm bracket and installing the sway bar on the outside of the brackets. Since the clips do not fit the bracket, I am going to have to buy hardware to properly secure the sway bar.
The sway bar is barely above the scrub line.
The ABS line was not long enough to snap back into the bracket so I wire tied it to the brake line until I figure out something else.
Other than the issue with the sway bar mounts, I pleased with the kit.
