steeda balljoints
rio94
anyone using these if so how much did they lower your car without the spring spacer. Does the car drive better with them
R
rio94
sorry i was reffering to the x2 balljoints, my car has eibach sportlines and tends to wander and has some bumpsteer with the 275/40/17 on the front
ryclef331
you have two choices with the x2...regular ride height or the half inch drop. Its you either run with the spacer or not that comes with the kit.
19mustang95
wow, i never new that they lowered the car, i only thought they helped correct the suspension for when you lower it.
Matt94GT
bumpsteer is what is caused by cars SOMETIMES when there lowered, you will feel the car pulling from one side to the other slightly over bumps etc. lots of old roads cause this which is slightly normal but will be will alot more noticable and pretty bad if you have bumpsteer problem. Personally my car is lowered over 2" in the front and I dont have bad bumpsteer.
qzxo_oxzp
