For Sale Stinger PiMPxs ECU, dual widebands, etc $400 shipped (48 states)
StangerYSI
Ontario Canada
I've changed to a different strategy on my 94 so the ECU is up for sale.
In addition to the base pimpxs kit this also has a second wideband (so you can correct fuel metering per cylinder bank) and also the auxiliary I/O cable so you can have more inputs and outputs for whatever you might want to run.
This was set up to run a 1994 GT and will include a base program for a naturally aspirated 1994 gt as well as all the documentation that Stinger sent me on a thumb drive. You'll need to get your own license for TunerStudio if you don't already have one.
By changing jumper positions this is also compatible with 86-93 5.0 foxbody, 87/88 Thunderbird turbo coupe, 83-89 XR4Ti & 2.3 SVO. This ECU is able to support sequential fuel and coil-on-plug (or coil-near-plug) distributorless ignition.
Also if you want I can include a factory 94/95 airbox/tube with the MAF removed and the wiring pigtail plugged, since the pimpxs doesn't use MAF there's no reason to have that restriction.
A note on installation: I am not in a position to offer technical support on this, I have two jobs and a disabled dependent plus my own project cars to work on. This came off a good running Mustang and does not have any problems, but installing something like this is not a job for someone who struggles with oil changes or properly wiring a car stereo. Don't buy this if you aren't sure you can handle it. The documentation Stinger provided me is included and there's a nice forum on Stinger's website.
Here's what is included:
Stinger PiMPxs ECU
USB drive with Stinger documentation and base tune for naturally aspirated 1994 Mustang GT
Two wideband o2 sensors and controllers as included from Stinger originally - these click into your existing harness but you have to find somewhere dry to mount the controllers
Stinger aux I/O harness - take note that the wires on it have been shortened from their original length. There's still more than a foot of every wire, nothing's been nubbed.
Panel mount USB extension cable
Optionally I can include an original airbox/hose with the MAF deleted and the wiring grommet plugged. See photos.
I'll ship it within the continental USA for $400, if you're somewhere else let's talk about shipping stuff.
Still available?
Lucky57
