stock gears????????????????
T2000
what came stock on 94 -95's
need to prove my point
help me out :banana:
If you ever wondered what gears your car has stock. Look at the door tag inside the driver side door. this applies only to the 86-95 5.0
Where it says AX on the far right on the bottom it will say 1 of the following 3 letters. M,Z and E.
M=2.73:1
Z=3.08:1
E=3.27:1
Obviously your door tag has to be intact to beable to get the info this way.
Hope this helps some people that always wondered what rear gear ratio there car originally came with or still currently have.
If you dont have either of those, jack up the car, mark a line on the rear tire it dose not matter which side, then make a mark on the driveshaft, rotate the tire one full turn while counting how many times the driveshaft goes around.
SVTGizzi
i manually rotated my tire and counted the driveshaft revolutions my 95 is stock with a 3.08, but like they said thats not the only option.
there is also a tag on one of the bolts on the differential cover saying what the ratio is
Snowed
If the letter codes above are right, my 94 gt auto came with 3.27 stock?
Steven
SC
DDSTANG94 said:
most 94-95 came with 2:73
most fox bodys come with 3.08
wrong, thats the other way around. Worked in a junkyard for 3 years, almost all the foxes that came through were 2.73, almost all snives were 3.08s
Cregar24
