Strange sound behind the dash at high rpm
Discussion in '96-04 - 2V Specific' started by Adam Vinnicombe, Nov 19, 2020.
  1. evilcw311
    evilcw311 Most Evil Member! SN95 Supporter
    7,459
    2,079
    May 9, 2010
    Louisville, KY
    Thats more for those who mess with tuning. You should definitely see a change but I’m not sure how those numbers would swing. While you were fixing the one line did you take the time to verify there was no other leaks??
  2. Adam Vinnicombe
    Adam Vinnicombe Active Member
    412
    63
    Jun 28, 2019
    I’ve look all over the car now and have not found any other vacuum leak at all. What I did do as an experiment as I am still learning the basics here was to plug in my data logger and watch the fuel trims at idle, then I pulled the blue vacuum line back of and watched the STFT instantly react by going +8 while at idle and slowly decrease back to +1 as the rpms went up. So I can definitely say that that little vacuum leak was messing the fueling up when at idle
  3. ttocs
    ttocs Post Whore
    26,087
    2,893
    unmetered air would have to throw those off I would think.
  4. white95
    white95 Apex Junky Admin
    16,879
    3,408
    Dec 30, 2007
    30.31469, -90.94575
    Smoke test
    Smoke test
    Smoke test
    Smoke test
    Boostr1, evilcw311 and Werecow like this.
  5. evilcw311
    7,459
    2,079
    May 9, 2010
    Louisville, KY
    You can’t do a visual check for vacuum leaks. Either get a smoke machine to test it or do what I do and get a cigar and do it the cheap easy way.
    Smoke test is your easiest way to verify no more leaks.
    Werecow likes this.
  6. Werecow
    Werecow Well-Known Member
    1,041
    774
    Feb 3, 2020
    Virginia
    ^^^^ agree... Then dig out yer trusty ol vacuum guage...
  7. Adam Vinnicombe
    412
    63
    Jun 28, 2019
    Right today I’m going to go and see if I can buy me a vacuum gauge but as I said I’m still learning here where is the best place to plum it in ?
  8. Adam Vinnicombe
    412
    63
    Jun 28, 2019
    Well some good news done the cigar smoke test and found no leaks anywhere which was nice but my fuel trims are still negative at idle but all jump to a constant 0 to +3 just above idle when in neutral
  9. vitory34
    vitory34 New Member
    Dec 15, 2020
    I found interesting information about information about Torque of differential and driveshaft , and also how the Temperature can affect to the performance.
    www.motorcloud.com
