STUPID FREAKING EGR!
GT3FC
Phoenix, Arizona
I'v been dealing with a vacuum leak for a while now and I finally figured out it is coming from the bottom of the EGR valve. Problem is I cant get the Damn EGR valve bolted up right because the pipe from the exhaust manifold that that Attaches to the EGR sags so bad and with such force that I am unable to bolt my EGR on and get a good seal. Anyone have any experience or any ideas of how I can get this bolted up right?
chris91
Cincinnati, OH
Unbolt the upper Plenum and then bolt the EGR to the Plenum and then bolt your Plenum back up.
GT3FC
GT3FC
Phoenix, Arizona
Oh my god thats freaking genius! ill try it tomorrow! your awesome thank you so much I have spent the last 3 hours trying to get this right
GT3FC
GT3FC
Phoenix, Arizona
the problem is its too low because of my nitrous plate raising the plenum so the EGR is lower than the plenum. the pnly thing i can think of is to take the plat out, connect the EGR then try and slide the plate under the plenum. the only hard part about that would be getting the gasket lined up correctly
CC'S95GT
Hampton ,Ga.
How bout making a new tube that connects the EGR to the header. An exhaust shop might be able to help also.
chris91
Cincinnati, OH
Mine had plenty of room when I had it off. Do a Google search and see if this is a common problem with the plate setup. If it is I'm sure someone else has posted about it.
GT3FC
GT3FC
Phoenix, Arizona
Thanks everyone I got it on and it really wasn't too bad. I took the egr off then took the plate and plenum off and left the plenum unbolt ed while reconnecting the egr then slid the Plate and gasket underneath the plenum
wbarter
